tham 12 mo ใช้ดอกนี้พอไหวไหมครับ p120/130lf เสียงจะออกมาอย่างไรน้อ......
Specifications
Nominal Basket Diameter
12"
Impedance
8 ohms
RMS Power Rating
400 Watts
Program Power 800 Watts
Frequency Response
32Hz - 2.5kHz
Sensitivity (1W/1m)
97dB
Voice Coil Diameter
3.94" / 100mm
Mounting Information
Overall Diameter
12.52" / 318mm
Bolt Circle Diameter
11.81" / 300mm
Baffle Cutout Diameter-
- Front Mount 11.2" / 284.5mm
No. Of Mounting Holes
8
Overall Depth 4.85" / 123.3mm
Net Weight 20.68 lb. / 9.4 kg.
Materials
Basket
Die Cast Aluminum
Cone
Paper
Surround
Treated Cloth
Voice Coil
Copper Clad Aluminum Wire
Magnet Ferrite
Former Material Glass Fiber
Terminal Type Gold Plated Push
Thiele-Small Parameters
Resonant Frequency (fs)
48 Hz
Impedance (Re)
5.3 ohms
Coil Inductance (Le) 1.44 mH
Mechanical Q (Qms)
5.07
Electrical Factor(Qes) .28
Total Q (Qts)
.26
Comp. Equivelant Vol. (Vas)
2.13 ft3 / 60.27 Liters
Effective Surface Area (Sd)
.053 m2
Voice Coil Overhang (Xmax) 5.5 mm
Reference Efficiency 2.33%
